LMS 2.5 Installation
Answered Question
Jun 4th, 2007
I was advised to install LMS 2.5 on a separate server from the current live LMS 2.2 version I have running. Is it an upgrade where I have to install the older version first or can I do a clean install with the new 2.5 CD's?
Correct Answer by Joe Clarke about 10 years 3 weeks ago
You can do a clean installation of 2.5 on the new system. If you have an upgrade license, you will need to validate your LMS 2.5/2.6 installation by pointing to the existing 2.2 server. Validating an upgrade is documented in the installation guide.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 06/04/2007 - 08:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
