Need helpt to change extensions
Jun 4th, 2007
We need to change around 1000 extensions and also change from 4 digits to 5 digits on an existing call manager.
Is there a way we can do with some tools or XML applications? I really don't want to change those manually.
CM is 4.1.3 sr3
Thanks for your help.
Bala
balukr Mon, 06/04/2007 - 08:56
Brandon,
I knew about the BAT tool.It pulls lot of information when you try to query about the phones.I'll try that again.
Thanks for your help though.
Bala
Brandon Buffin Mon, 06/04/2007 - 11:46
  • Purple, 4500 points or more
Bala,
Yes, you can use the BAT tool to accomplish this. You could export the existing phones to a .csv file, fix up the file and use the .csv to update the phones. Take a look at the BAT User Guide below.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_user_guide_chapter09186a00807184bb.html
Hope this helps. If so, please rate the post.
Brandon
