ASA 5505 Easy VPN to headend PIX 515e
Jun 4th, 2007
I have a PIX 515e headend unit (running 7.0) with multiple 3002 hardware clients connecting using Easy VPN. Purchased an ASA 5505 as a replacement for one of the 3002 devices and am having issues.
I can get the ASA to connect to the PIX using Easy VPN remote mode and can access the ASA through my enterprise network. However, the client PCs connected to the ASA cannot access my enterprise network.
When I try pinging from the ASA to my enterprise network using ASDM it will fail unless I specify the inside interface. I have reset the device and only setup the Easy VPN remote settings and still have the same issue.
What am I missing?
Thanks in advance for any help!
