ISDN Switch
Answered Question
Jun 4th, 2007
Hi every one!!!
Can i make work a router like a ISDN Switch if is provided with the proper interfaces?
I need to know since i want to practice !!!!
Thak you!!!
Correct Answer by paolo bevilacqua about 9 years 11 months ago
Good luck.
Please consider rating useful posts as an appreciation to those providing answers!
Overall Rating: 4 (1 ratings)
sundar.palaniappan Mon, 06/04/2007 - 13:41
  • Green, 3000 points or more
AFAIK routers can't function as an ISDN switch. You can get an ISDN simulator for pretty cheap now-a-days on ebay.
Sundar
paolo bevilacqua Mon, 06/04/2007 - 13:50
  • Hall of Fame,
    Founding Member
Yes. FOR ISDN BRI, the VIC-2BRI-NT/TE and VIC2-2BRI-NT/TE can be configured as "network side" and can emulate most switch behavior. Also, all T1/E1 PRI interfaces can do the same.
See the following document:
http://cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00804794c6.shtml
Hope this helps, please rate post if ti does!
sundar.palaniappan Mon, 06/04/2007 - 13:58
Interesting!! Good to know that the router can switch ISDN calls.
Just wondering whether Paul has the needed hardware to do this. If he doesn't he's probably better off getting an ISDN emulator which is probably a lot cheaper than getting the Cisco gear to practice.
Sundar
paolo bevilacqua Mon, 06/04/2007 - 14:39
  • Hall of Fame,
    Founding Member
Yes, probably cheaper. But with the voice BRI one can study voice as well that is in most voice certifications nowadays.
Paul Webster Tue, 06/05/2007 - 06:46
i Highly appreciate your advices, Now I will try which option is the best!!!
Correct Answer
paolo bevilacqua Tue, 06/05/2007 - 10:53
  • Hall of Fame,
    Founding Member
Good luck.
ariela Thu, 06/14/2007 - 13:29
  • Silver, 250 points or more
Hi Paolo,
I agree with you, just a little addition: that solution works only with NT/TE, so for voice traffic, no data.
Regards ;)
Andrea
paolo bevilacqua Thu, 06/14/2007 - 13:34
  • Hall of Fame,
    Founding Member
Andrea, what do you mean ?
Look at the document linked above. The ISR router can switch voice and data calls, no problem.
