mohammedmahmoud Mon, 06/04/2007 - 22:52
  • Green, 3000 points or more
You should most probably have a one-to-one relation between VRFs and VLANs according to your design.
As for configuring BGP per VRF, you need to use address-families, something like this:
ip vrf test
rd
interface x
ip vrf forwarding test
ip address x.x.x.x
router bgp
address-family ipv4 vrf test
neighbor remote-as
network mask
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
ariela Mon, 06/04/2007 - 23:42
  • Silver, 250 points or more
just a little specification:
interface x = interface vlan x ;)
interface vlan x
ip vrf forwarding
ip address x.x.x.x
Andrea
mohammedmahmoud Mon, 06/04/2007 - 23:46
Hi Andrea,
You are most probably right :)
But i didn't know the original poster's topology (i mean how does he do the inter-VLAN routing), he might be doing router-on-a-stick, and thus i gave it to him in a generic manner and he should work it out.
BR,
Mohammed Mahmoud.
ariela Tue, 06/05/2007 - 00:18
Yes, Mohammed,
you are right :)
The original post is generic ...
Andrea
