Cisco ASA Bridged DMZ
Jun 4th, 2007
I am trying to setup a Cisco ASA 5510 (with plus) to act as our main firewall as well as offer us DMZ services, for webserver/SSL Concentrators (Citrix and Cisco CVPN3015). What we would like to do is a dual homed DMZ, where one link is for the inside-DMZ and one link is for the outside-DMZ, where the SSL concentrators and webservers can act as their own gateways. The problem is on the outside / public DMZ, we would like to have this setup as a bridged network, between the outside interface and the outside-dmz interface. We still want to be able to filter on the outside-dmz interface, for security reasons.
Is there a way to do this? Do i need to setup a virtual outside interface to which the outside-DMZ interface is bridged?
The problem is, when reading the documentation on transparent firewalling, it seems to apply to the entire ASA, thus could be causing some problems since we are nat'ing the inside network to the outside and utilizing the CSC-SSM module for some data filtering for the inside network.
Actually we are using PAT as defined on the asa, not like ios router with nat overload statement. If someone knows a better way to do nat like in ios on a ASA , where we nat many inside addresses to one outside address, please let me know.
So anyone have any suggestions on implementing a bridged DMZ?
Overall Rating: 3 (1 ratings)
iroccorp.com Fri, 06/08/2007 - 09:08
Hi Andrew,
This is the conclusion i have come to aswell. I am trying to figure out how to get the routed mode to work right now and it seems there is something i am doing wrong, as data just wont route across the interfaces, even when setting the access lists.
See the post:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddebeb0
Any hints?
acomiskey Fri, 06/08/2007 - 09:17
From you other post you said you
"be able to let network traffic, between the inside network and the inside DMZ to pass freely ."
For that you should need something like this
static (inside,INSIDE-DMZ) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
does that help?
also, to initiate from the INSIDE-DMZ to the inside you would need to have an acl in interface INSIDE-DMZ
acomiskey Fri, 06/08/2007 - 09:21
You also want...
" to be able to route the public address space across the ASA, between the E0 and E1 interfaces"
try this...
static (OUTSIDE-DMZ,outside) 72.13.113.0 72.13.113.0 netmask 255.255.255.128
iroccorp.com Fri, 06/08/2007 - 09:29
does the static command mean access list permissions / routing permissions, or does it have something to do with NAT. I don't want to use NAT on the DMZ ..
thanks
acomiskey Fri, 06/08/2007 - 09:32
It has to do with nat, but when it's written how it, it will not nat. There needs to be a translation in the ASA for communication from higher to lower security interface. You could also do this...
access-list nonatdmz extended permit ip any 192.168.50.0 255.255.255.0
nat (inside) 0 access-list nonatdmz
Does that make sense?
acomiskey Fri, 06/08/2007 - 09:45
Also just noticed that your security levels for inside and inside-dmz are both 100. You will need this command as well for communication between same security level interfaces OR change the security level on inside-dmz to something between 100 and 10.
same-security-traffic permit inter-interface
iroccorp.com Fri, 06/08/2007 - 12:20
I can ping from the inside interface to the inside DMZ interface now, but can't do it in reverse. the same-security-traffic permit inter-interface didn't seem to help anything ..
acomiskey Fri, 06/08/2007 - 12:24
Can you post a clean config? Is your outside-dmz working as you wish?
Also, should the inside-dmz really be the same security level? I would assume it is less secure than your inside. I would recommend to lower the security on it. Leave the existing static (inside,inside-dmz)... then write an access-list that applies in interface inside-dmz to allow that traffic into your inside network.
iroccorp.com Fri, 06/08/2007 - 12:36
seem to be having a issue with pinging anything outside (aka ICMP traffic seems to be denied right now). Anyways, here we go. PS: we also are using OSPF on the inside network.
ASA Version 7.1(2)
hostname firewall
domain-name example.com
names
interface Ethernet0/0
nameif outside
security-level 0
ip address 72.13.113.129 255.255.255.240
interface Ethernet0/1
description DMZ Outside Interface
nameif dmz-outside
security-level 10
ip address 72.13.113.1 255.255.255.128
interface Ethernet0/2
description DMZ Inside Interface
nameif dmz-inside
security-level 100
ip address 192.168.50.1 255.255.255.0
ospf network point-to-point non-broadcast
interface Ethernet0/3
nameif inside
security-level 100
ip address 192.168.100.1 255.255.255.0
ospf message-digest-key 1 md5
ospf authentication message-digest
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
clock timezone MST -7
clock summer-time MDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
name-server xxx.xxx.xxx.xxx
pager lines 24
mtu outside 1500
mtu dmz-outside 1500
mtu dmz-inside 1500
mtu inside 1500
no failover
asdm image disk0:/asdm512-k8.bin
asdm history enable
arp timeout 14400
nat-control
global (outside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0
static (inside,dmz-inside) 192.168.100.0 192.168.100.0 netmask 255.255.255.0
static (dmz-outside,outside) 72.13.113.0 72.13.113.0 netmask 255.255.255.128
route outside 0.0.0.0 0.0.0.0 72.13.113.129 1
router ospf 1
network 192.168.50.0 255.255.255.0 area 0
network 192.168.100.0 255.255.255.0 area 0
area 0 authentication message-digest
log-adj-changes
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
linkup linkdown coldstart
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh scopy enable
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 10
console timeout 0
dhcpd address 192.168.100.25-192.168.100.35 inside
dhcpd dns 192.168.100.25
dhcpd wins 192.168.100.25
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd domain example.com
dhcpd auto_config inside
dhcpd enable inside
class-map HTTP
match port tcp eq www
class-map inspection_default
match default-inspection-traffic
class-map outside-class
match access-list outside_mpc_in
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map outside-policy
class outside-class
csc fail-open
policy-map inside-policy
class HTTP
csc fail-open
service-policy global_policy global
service-policy outside-policy interface outside
service-policy inside-policy interface inside
acomiskey Fri, 06/08/2007 - 12:40
I added to my last post above in case you didn't see it.
You don't need both of these, you can get rid of one or the other.
To allow ping in from outside,
access-list outside_access_in extended permit icmp any any
access-group outside_access_in in interface outside
iroccorp.com Fri, 06/08/2007 - 12:54
This seems to work for the pings. Thanks.
What would the access-list / group look like to allow for traffic from the dmz-inside to the inside interface ?
acomiskey Fri, 06/08/2007 - 14:13
It depends on what you wanted to allow but it would look like this, what you are doing here is writing statements to allow traffic from dmz-inside to inside, then you are denying everything else from dmz-inside to inside, then you are allowing the dmz-inside to go everywhere else(outside).
access-list insidedmz_to_inside extended permit
access-list insidedmz_to_inside extended deny ip any 192.168.100.0 255.255.255.0
access-list insidedmz_to_inside extended permit ip any any
access-group insidedmz_to_inside in interface dmz-inside
