Aironet 1100 won't show IP Addr. w/ IPSU
Jun 4th, 2007
I am trying to set up a Aironet 1100. I enter the mac addr. into the IPSU and get a error - device does not answer. I've reset the device, ng. Tried 2 different computers, ng. I cannot get to the config. page. Any ideas?
scottmac Tue, 06/05/2007 - 06:39
You must be on the same LAN/VLAN segment for IPSU to work (no routers or L3 switches).
Good Luck
Scott
perrypillard Thu, 12/13/2007 - 08:47
I am having the same problem, and I am on the same LAN. We have two AP's and I can pull the other's IP just fine.
perrypillard Thu, 12/13/2007 - 10:02
Just to be sure, I unplugged the good-reporting AP and plugged in the not-so-good one in it's place. Still can't pull IP. Officially frustrated.
fourwindsri Thu, 12/13/2007 - 14:41
I took mine apart and found a different macd addr on the transmitter card inside. Tried that and failed!
fourwindsri Thu, 12/13/2007 - 09:34
I've tried going direct from every network port on every pc I own! Still won't work!
fourwindsri Thu, 12/13/2007 - 09:36
No, I'm living with it for now! I have it set up for a wi-fi vacation rental next door to my house. I've turned offf all sharing on the computers for this house when we have renters & shut it down when vacant.
andrew.brazier@... Wed, 12/19/2007 - 06:11
I've never managed to get the IPSU working, never, not once! The alternative is to check your DHCP server for the MAC address of the AP to see which address it has leased. No hassle, works every time.
perrypillard Wed, 12/19/2007 - 06:17
Unforetunately, we have a simple workgroup network, and the only DHCP system we have is a simple VPN router, which only reports up to 25 connections. Very frustrating.
We have plans to upgrade to real domain server, but haven't got enough of our immediate brush fires out to jump on that project just yet.
andrew.brazier@... Wed, 12/19/2007 - 06:24
Plan B: Get yourself a copy of tftpd from here:
http://tftpd32.jounin.net/
A very lightweight TFTP & DHCP server (amongst other things). Install on a PC and connect to the new AP with a cross lead (or in such a way that the PC and AP are isolated from the main LAN). Start TFTPD and configure a DHCP scope, power on the AP and watch the TFTPD log screen. Connect to the AP with a browser and give it a static address on the main LAN.
Plan C: Connect a console cable to the AP and reboot it, watch the boot process carefully and you'll see the IP address it leases.
