Tool for configuring multiple routers based on a template
Jun 4th, 2007
I frequently roll out networks which have multiple sites that are identical except for variables like IP address, passwords and hostnames. Is anyone aware of a tool where you can customise a template and generate multiple configurations in txt format ready to distribute to people/devices. Up until now I have been using excel but I am looking for something that may offer more features. Note I am not after management software, only template to configuration generator to save time on copying and pasting, and to reduce the error of data imput on large volume rollouts.
avmabe Tue, 06/05/2007 - 10:55
  • Bronze, 100 points or more
I think you already are using the best tools, it is just a matter of streamlining your copy and pasting.
I personally use text documents and use a "template" which is just a test doc. I copy and paste.
I don't know of a way that works more accurately and fast as what you are doing today.
