06-04-2007 06:05 PM - edited 03-03-2019 05:18 PM
hi all,
this my first time here....hope you can help me.
i have 2XT1,2811,WIC-1DSU-T1,WIC-1DSU-T1-V2.
I am going to bundle them with MFR (hope that will work if not i will use MLPPP).
My problem is that my 2811 doesn't recognize the WIC-1DSU-T1. when the router loads i get ERR MSG: "%GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 11"
I think it is a version problem but don't know for sure and don't know what version to use.
i have 2 ISOes:
1 -rw- 19256532 Dec 09 2005 17:44:20 +00:00 c2800nm-advsecurityk9-mz.124-3a.bin (Version 12.4(3a) currently runs )
9 -rw- 29414328 May 04 2007 14:54:16 +00:00 c2800nm-advipservicesk9-mz.123-11.T3.bin
both do not recognize the WIC.
second problem is that i can't config BGP i get ERR "Protocol not in this image"
any ideas?
06-04-2007 07:24 PM
As per the product support document Cisco 2800 series routers support WIC-1DSU-T1-V2 cards.
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016fa68.html
Are you facing problems with WIC-1DSU-T1 or WIC-1DSU-T1-V2 card ?
To configure BGP you can try booting the router with the advipservices feature set..
You can achieve the same by altering the boot system statement in the config...
regds
06-04-2007 08:11 PM
hi Thanks for the response,
the version type solved the BGP problem.
i put the "c2800nm-advipservicesk9-mz.123-11.T3.bin" to work.
but it stil don't recognize WIC-1DSU-T1.
any ideas?
06-04-2007 08:15 PM
As i mentioned in my previous reply V2 cards are supported with these boxes i dont think you will be able to use the normal WIC-1DSU-T1 card..
regds
