Warning message
Regarding a bad block number error in 3560
Jun 4th, 2007
Hi all,
Can anyone check this error messages which i am getting in 3560 Switch while intilizing the flash in Recovery mode?
Base ethernet MAC Address: 00:1b:2b:9f:4f:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: Checking block 201...bad block number (-21778)
flashfs[0]: erasing block 201...done.
flashfs[0]: Checking block 202...bad block number (-21782)
flashfs[0]: erasing block 202...done.
flashfs[0]: Checking block 201...bad block number (-1297)
flashfs[0]: Inconsistency in flash found on second pass
...done
Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
The system has been interrupted, or encountered an error during initializion of the flash filesystem. The following
commands will initialize the flash filesystem, and finish loading the operating system software:
flash_init
load_helper
boot
Kindly revrt back to me.
Rgds
Senthil
Amit Singh Mon, 06/04/2007 - 20:28
  • Cisco Employee,
Senthil,
The flash error you're getting is a physical
problem on the Flash itself.
Try formatting the flash " format flash:" and then try initializing the flash using
flash_init
load-helper
If that works then you are good to go, Otherwiese go ahead and get an RMA for the 3560 switch as it has a bad flash hardware.
HTH,Please rate if it does.
-amit singh
