Deny Inbound Message
Jun 4th, 2007
I am having an issue with trying to get a ping through a PIX515 with OS6.2(4). The message I keep getting, and I am unsure as to why, is as follows:
106011: Deny inbound (No xlate) icmp src ACCNT:ACCA2-BK_Fas00 dst ACCNT:ACCAS1_Tunnel3 (type 8, code 0)
The config is attached. I would be grateful if someone could assist please.
Timothy
By default the PIX does not allow inbound ICMP packets. ICMP is somewhat stateless and thus Ping will not work outbound unless you explicitly allow certain packets in through the access-list. I.e.
access-list inside_access_in permit icmp any any unreachable
access-list inside_access_in permit icmp any any echo-reply
access-list inside_access_in permit icmp any any time-exceeded
access-list inside_access_in permit icmp any any traceroute
tbogie_gvds Wed, 06/06/2007 - 23:51
Wouldn't these statements do roughly the same thing?
name 172.16.4.138 ACCAS1_Tunnel3
name 172.16.4.6 ACCA2-BK_Fas00
pdm location ACCA2-BK_Fas00 255.255.255.255 inside
object-group network GRE_Tunnel_INSIDE
network-object ACCA2-BK_Fas00 255.255.255.255
object-group icmp-type Management_PING
icmp-object unreachable
icmp-object time-exceeded
icmp-object echo-reply
icmp-object source-quench
access-list inside_access_in permit icmp object-group GRE_Tunnel_INSIDE host ACCAS1_Tunnel3 echo
access-list ACCNT_access_in permit icmp host ACCAS1_Tunnel3 object-group GRE_Tunnel_INSIDE object-group Management_PING
static (inside,ACCNT) ACCA2-BK_Fas00 ACCA2-BK_Fas00 netmask 255.255.255.255 0 0
access-group inside_access_in in interface inside
access-group ACCNT_access_in in interface ACCNT
route inside 172.16.4.4 255.255.255.252 ACCANSBK_Untrust
route ACCNT ACCAS1_Tunnel3 255.255.255.255 ACCA3_FastEth00 1
