SAS 70 Audit Requirements
Jun 4th, 2007
  • Gold, 750 points or more
I have to propose a network which is in compliance with SAS 70 Audit.
The network is very simple. Internet Link will terminate on my ASA 5505 and from there the wires will go into my 1200 APs.The network consists only of Laptops.I will be using 802.1X authentication and would use encryption.
Also in ASA a IPSec VPN connection to my US office will terminate. Now this network as said would undergo security audit.
So my problem is that I am clueless. Is ACS server required for SAS 70?or will the current setup is OK. IF anyone has done this then please help.
Thanks in advance
JD
Trending Topics - Security & Network
