adding incoming numbers
Jun 4th, 2007
Hi All,
We have a Cisco 2801 Router with a 15 Channel ISDN and an internal IP Telephone System. Our Phone Service Provider has already given us a 100 range of numbers attached to the 15 Channels, but is going to add 2 additional individual numbers completely outside of this range.
I need to know that our router will accept calls for these numbers and pass them to our IP telephone server to determine which extension is to receive the call.
Currently I see two areas that refer to our 100 range as it is now. Would I need to add these 2 individual numbers in these areas as well?
translation-rule 22
Rule 1 02811780 811780
and the following I believe is only for outgoing calls which does not matter, I do not need calls to me made outgoing via these 2 additional numbers.
dial-peer voice 3 voip
translation-profile outgoing calling
destination-pattern 811780..
voice-class codec 1
max-redirects 10
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
no vad
If I have not made any sense, please ask me any questions you may have.
Thankyou in advance for your help.
drolemc Fri, 06/08/2007 - 12:18
  • Silver, 250 points or more
Called number (DNIS) with incoming called-number
First, the router or gateway attempts to match the called number of the call set-up request with the configured incoming called-number of each dial-peer. Since call setups always include DNIS information, it is recommended to use the incoming called-number command for inbound dial peer matching. This attribute has matching priority over answer-address and destination-pattern.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
pjscott13 Wed, 07/11/2007 - 23:11
Yeah we already had that set up. I just did not include it in my post.
dial-peer voice 1 pots
voice cut-through alert
description Incoming ISDN Dialpeer
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 2 pots
description Outbound DialPeer
destination-pattern 0T
port 0/1/0:15
destination-pattern 866780..
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
dial-peer voice 4 voip
destination-pattern A800AT
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
dial-peer voice 5 voip
destination-pattern .
voice-class codec 1
max-redirects 10
dtmf-relay rtp-nte
no vad
I'm still not sure what to do here though. I think I might have a translation issue.
