Bandwidth Usage by Routing Protocol & Keep-alive (Important Information)
Jun 4th, 2007
  • Gold, 750 points or more
Hello All,
We have BGP & OSPF in our Network. Also we have implemented "Keepalive" command for the VPN Link.
Since the VPN Link is for Backup Purpose but i see approxmiate usage of 50 kbps / 100 kbps of Link Usage on Continuous Basis.
Is this Usage because of Routing Protocol Updates & Continuous Keepalive Packets sent on Link ? ?
Kindly adivce on the Same. Awaiting for your earlier Updates.
Best Regards,
Guru Prasad R
Overall Rating: 3 (1 ratings)
bjornarsb Mon, 06/04/2007 - 21:26
  • Bronze, 100 points or more
Yes , you are correct.
BR,
Bjornarsb
guruprasadr Tue, 06/05/2007 - 02:52
Thanks for your Confirmation.My suspection was correct. Is there any Document showing this Information ? ?
Best Regards,
Guru Prasad R
