HELP urgent - Install NM-1T3/E3 card in 3745
Jun 4th, 2007
I just installed NM-1T3/E3 in Cisco 3745. As my understanding, neither Cisco 3745 nor NM-1T3/E3 support OIR. So before i install the card, i power off the router. After i installed the card, i power on the router again. When I show ip int brief , i didnt see the card in the output. But when show diag, i saw the card was installed in slot 4. Can you anyone explain why this happened?
SAM
Overall Rating: 4 (1 ratings)
spremkumar Mon, 06/04/2007 - 22:50
  • Red, 2250 points or more
Hi SAM
Can you post the output of show version here ? and also Whats the ios version you are running out there ?
regds
sam-lee Mon, 06/04/2007 - 22:58
This is the output of show version
IOS (tm) 3700 Software (C3745-JS-M), Version 12.2(15)T16, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Tue 19-Apr-05 11:23 by ssearch
Image text-base: 0x60008954, data-base: 0x61E40000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
ROM: 3700 Software (C3745-JS-M), Version 12.2(15)T16, RELEASE SOFTWARE (fc2)
C3745 uptime is 2 days, 3 hours, 55 minutes
System restarted at 21:21:15 CST Sat Jun 2 2007
System image file is "flash:c3745-js-mz.122-15.T16.bin"
cisco 3745 (R7000) processor (revision 2.0) with 248832K/13312K bytes of memory.
Processor board ID JPE083330KV
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
8 Serial network interface(s)
1 ATM network interface(s)
1 Subrate T3/E3 ports(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
125184K bytes of ATA System CompactFlash (Read/Write)
SAM
mohammedmahmoud Mon, 06/04/2007 - 23:10
  • Green, 3000 points or more
Hi Sam,
You have to configure the channel-group under the controller for the serial interface to appear in the show ip interface brief. (the serial interface appears dynamically just after you configure the channel-group)
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
sam-lee Mon, 06/04/2007 - 23:16
Hi Mahammed,
Can you tell me how do configure the channel-group under the controller for the serial interface?
SAM
mohammedmahmoud Mon, 06/04/2007 - 23:25
Hi SAM,
It should look something like this, but you'll need to consolidate the linecode, framing and time-slots with your provider:
controller e1
linecode {ami | hdb3}
framing {crc4 | no-crc4}
channel-group timeslots
After doing the above configuration, a serial interface with the same channel-number will be dynamically created, and its where you'll put the IPs and any other relevant configuration.
interface Serial
I hope that i've been informative.
HTH, please do rate all helpful replies using the scroll box on the right,
Mohammed Mahmoud.
