IOS IPSec Encr.
Jun 4th, 2007
  • Bronze, 100 points or more
I'm looking for a document at Cisco.com talking about IOS IPSec encryption "software encryption" limitations, throughput .... per platform
any help?
Thanks in advance
Abd Alqader
Overall Rating: 3 (2 ratings)
Anonymous (not verified) Fri, 06/08/2007 - 12:20
AES encryption support has been introduced in Cisco IOS? 12.2(13)T. There are no hardware based IPSEC.
paolo bevilacqua Fri, 06/08/2007 - 13:48
  • Hall of Fame,
    Founding Member
Actually there are many hardware based IPSEC / encryption solutions is the cisco portfolio.
The ISR routers (all), the PIX/ASA, the older 17xx and 26xx with the appropriate modules, the 7200 with the SA, the 6500/7600 blades, these are all hardware based encryption solutions.
See the following document for a comparison of performance for different platforms:
http://cisco.com/en/US/products/ps6635/prod_brochure09186a00801f0a72.html
Note: there is not much data on software based encryption because is not adequate for any serious deployment but only the most casual low speed setup.
