Device Discovery problem
Jun 4th, 2007
I have two processes "RMEdbMonitor" and "CMFdbMonitor" that are shown as "Failed to run" in Common services >> server >> admin >> Processes. Moreover, the device discovery doesn't work, I have to run manually "RMEdbMonitor" process to run the discovery but when it ends process returns to "Failed to run" state and the discovery does not discover any device. Any help would be greatly appreciated. Thanks.
Overall Rating: 5 (1 ratings)
ahajivandi Tue, 06/05/2007 - 04:41
Apparently it is not possible to write to the property and log files on the D:\ disk.
Can you check if the file: d:\cscopx\campus\etc\cwsi\DeviceDiscovery.properties is available and can be written by Cisco "casuser"? The same situation goes for your log files in the D:\CSCOpx\log directory.
-Aryan
