Tunneling
Jun 4th, 2007
If we are using the two routers are our regional offfice, i want to know that what is the reason of making tunnel between the two location(Router)and how i have to do tunnel between them (Configuration)
And what are all the method of doing that
Please advice on the above points
Vinoth kumar.H
mohammedmahmoud Mon, 06/04/2007 - 23:31
  • Green, 3000 points or more
Hi Vinoth,
You need the tunneling in order to secure your traffic between your offices, the simplest tunnel technology to be used is GER tunnels, please do check it out:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_tech_note09186a008048cffc.shtml
http://www.cisco.com/en/US/tech/tk827/tk369/tk287/tsd_technology_support_sub-protocol_home.html
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Richard Burts Tue, 06/05/2007 - 03:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
GRE tunnels do encapsulate traffic being sent between the 2 routers but they do not provide much security. If you want to secure the traffic you need something like IPSec.
GRE tunnels are very useful if you want to connect routers over public links but use private addresses on each LAN. Also helpful if you want to run a routing protocol between the routers but they are not directly connected.
Rick
mohammedmahmoud Tue, 06/05/2007 - 04:06
Hi Rick,
You are absolutely right, i though of giving the simplest solution, thats why i suggested GRE, but as you've said if security is an issue, then IPSec would be perfect.
BR,
Mohammed Mahmoud.
