Router E1 Voice back to back connection
Jun 4th, 2007
The router serial port can back to back connction with DTE/DCE.
Can the E1 voice port do such kind of connectin also? how to do ?
paolo bevilacqua Tue, 06/05/2007 - 12:14
  • Hall of Fame,
    Founding Member
Sure it can. Look at the pinout an crimp a crossed cable. Configure both controllers for PRI switchtype primary-net5. On one router only, configure clock internal, and "isdn protocol-emulate network". Then configure dial-peers as necessary.
