06-05-2007 12:13 AM - edited 02-21-2020 01:33 AM
Hi there
I am trying to get people authenticated into the Cisco 3000 groups when connnecting using an IAS RADIUS server. It seems to only authenticate into the Base Group.
I know the answer is to send attibutes using the Remote Access Policy - but which ones?
06-12-2007 05:48 AM
You can make use of the following document
Configuring the Cisco VPN 3000 Concentrator with MS RADIUS
06-12-2007 04:06 PM
I figured it out already. You put the group in under the attribute 'Class' using the syntax OU=groupname;
The document you linked doesn't actually have anything about the groups. But thanks anyway.
