Two Internet links
Jun 5th, 2007
Hi, I have a question about Cisco Router 1841. I've got two 2Mbps Internet serial connections and two different LANs on my company location.Can I make it work with two WIC-1T and one Router 1841? I don't need NAT or load balancing at this device. I just want to forward from first Internet connection to PIX for first LAN and from second Internet Connection to router for second LAN? Help me!
mohammedmahmoud Tue, 06/05/2007 - 01:58
  • Green, 3000 points or more
Yes it can be done, you'll need PBR. Can you please post a simple diagram for the network and your needs.
BR,
Mohammed Mahmoud.
Amit Singh Tue, 06/05/2007 - 02:05
  • Cisco Employee,
Please paste the brief network topology and we will be able to help you..
-amit singh
mohammedmahmoud Tue, 06/05/2007 - 02:41
The LAN IPs are private IPs, and thus you'll be needing NATing, why did you said "I don't need NAT".
BR,
Mohammed Mahmoud.
zoranpopovic Tue, 06/05/2007 - 23:39
Hi Mohammed,
I don't need NAT on 1841 but you are right, I need it on PIX 506.I've sent you a little different addressing for that topology.Thank you very much for your help.
BR,
Zoran
