Main mode vs. Aggressive mode
Jun 5th, 2007
How to change from aggressive mode to main mode. I can not find any thing in Cisco documentation about how to use secret share and main mode together.
Jon Marshall Tue, 06/05/2007 - 02:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Are you talking about site-to-site VPN ?. Main mode is the default so you unless you have configured aggressive mode it will use main mode.
Jon
tajm Wed, 06/06/2007 - 00:13
Thanks for the replay
I am under the expression that Aggressive Mode is used for pre-shared keys and Main Mode is used for RSA-SIG based key exchange. Is this right ??
I have not specified any mode configuring the site to site tunnel so it?s mean I am using main mode ?
Please elaborate on this .
Jon Marshall Wed, 06/06/2007 - 00:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
No, by default main mode will be used for pre-shared keys and rsa-sigs as far as i know.
If you have not specified any mode when configuring it you should be using main mode. If you do a debug are you seeing MM_ entries when setting up Phase 1 as MM = Main Mode.
Jon
tajm Thu, 06/07/2007 - 00:08
Does any body know how to specify the aggressive mode ? I mean what is the command ??
jaffer_sathik2010 Thu, 06/07/2007 - 02:32
Enabling Main mode:
Router(config)#crypto isakmp aggressive-mode disable
/*It is implicitly there in router by default
Enabling Aggressive-mode:
Router(config)#no crypto isakmp aggressive-mode disable.
Plz rate if it helps.
--Jaffer
