Dual E1 vwic mft2e1
Answered Question
Jun 5th, 2007
I have a 3745 router and I have just replaced my single VWIC E1 card with a dual VWIC E1 card. However I only have 30 lines working. Can someone please tell me how to get the second E1 PRI ISDN line to work? Many thanks in advance.
Correct Answer by Paolo Bevilacqua about 9 years 9 months ago
No worries. You have:
dial-peer voice 104 pots
destination-pattern 0 <-- It should be really 0T, but if it works...
direct-inward-dial <-- Not needed for outgoing DP
port 3/0:15
You also need:
dial-peer voice 105 pots
destination-pattern 0T
port 3/1:15
This configuration uses multiple dual-peer and is not the more sophisticated trunk-group one. Its ok for your basic needs.
Note, under voice-port 3/0:15 you have some settings that you may want to replicate for 3/1:15 as well.
Note again, most of your dial-peer are redundant and could be eliminated/optimized.
Overall Rating: 5 (4 ratings)
Paolo Bevilacqua Tue, 06/05/2007 - 10:49
  • Hall of Fame,
    Founding Member
Do you use the PRI for voice? If so, do you have enough DSP resources to suppoer 60 channels ?
What is the exact error that you encounter ?
mintstreet Wed, 06/06/2007 - 01:17
The 2 PRI's are both used for voice. The VWIC is populated with all 5 DSP boards, so suffucient DSP's are available.
The problem I have is that the second PRI line is never used. Using "Show Voice DSP" or "Show Voice Call" I can see that only the first thirty lines are used for calls.
On the 31 concurrent call the softphone that I am using just says "Bad Number" or "Address Unknown": and there is no activity on the second PRI line.
I suspect it is an IOS setting which is not correct. I can swap the PRI lines in the router and always the first 30 work proving it is not a dodgy PRI line. I have two routers configured equally and the problem is on both of them ruling out a hardware fault.
Many thanks for your time.
Paolo Bevilacqua Wed, 06/06/2007 - 01:56
  • Hall of Fame,
    Founding Member
are these incoming our outgoing calls? "Show controllers E1" and "show isdn status" please ?
Finally, relevant router config please ?
mintstreet Thu, 06/07/2007 - 02:52
It is the same for incoming or outgoing calls, only the first 30 lines are used.
Here are the config and status's as reported by the router. I have added it as an attachment.
I sure hope you can help. Many thanks.
Paolo Bevilacqua Thu, 06/07/2007 - 03:07
  • Hall of Fame,
    Founding Member
For incoming, assuming both circuits are under the same hunt-group, telco has probably set things so that calls go fill the first circuit and then use the second. If you want a different behavior, ask them.
For outgoing, you do not have an outgoing dial-peer for the second interface. You can do that either creating a dial-peer, or putting both interfaces in a trunk-group, and referencing the latter in dial-peer.
Hope this helps,please rate post if it does!
mintstreet Thu, 06/07/2007 - 04:27
You say -
How do you identify a dial peer with interfaces? Sorry, I know I must be missing something which is obvious to you but I can't see it. Many thanks in advance.
mintstreet Thu, 06/07/2007 - 04:29
I think this is it - I have been concentrating on the Dial-peer voip one only.
direct-inward-dial
port 3/0:15
I guess I need another one for port 3/1:15??
Correct Answer
Paolo Bevilacqua Thu, 06/07/2007 - 04:36
  • Hall of Fame,
    Founding Member
port 3/0:15
You also need:
port 3/1:15
mintstreet Thu, 06/07/2007 - 05:19
p.bevilacqua
Many many thanks for your kind assistance.
Roger that on the replication of settings and now that I have a better, but still small, understanding of dial-peers, I will delete the gratuitous ones. Best regards - Steve
Paolo Bevilacqua Thu, 06/07/2007 - 05:54
  • Hall of Fame,
    Founding Member
Glad that helped, thanks for the nice rating, and best luck!
