06-05-2007 02:56 AM - edited 02-21-2020 01:33 AM
What ports should be opened on FireWall for LMS 2.6 ? The LMS server , management stations and devices - everything is in different network segments.
Please , advise.
06-05-2007 04:24 PM
Hi.
Here is the list of port utilization for LMS:
Hope this helps,
-Joe
06-06-2007 12:27 AM
Hello, Joe.
I saw that document , however according to my expirience ( at least with LMS 2.2 and 2.5) there is some "undocumented" ports. For example , Campus Manager uses some range of dynamic ports between client and server. Do you know what's the range ? Anything else not documented ?
06-11-2007 06:23 PM
We used to use some random ports above 1024 in older releases with regards to Corba. Now, all you'll need are the ports listed in the above mentioned link
07-10-2007 10:41 PM
Thank you very much. However , when we try to use IPM client(windows) , i still can see not documented ports above 2000 ...
07-11-2007 06:09 AM
Which undocumented ports aren't passing through for IPM?
