autoselect ppp problems
abgromov
After upgrading old C2500 analog dial-in router with ext. modem pool and with IOS v.11.2.17 to new C3845 router with int. NM-8AM-V2 and IOS v. 12.4.10 i have folloing problems:
1. ppp session does not starts automatically with
'autoselect ppp' command in configuration
2. ppp session starts only when both 'autoselect ppp' and 'autoselect during-login' are configured, but remote users need access both EXEC-mode and PPP-mode w/o 'autoselect during-login' command and Username prompt.
Any ideas?
Router C2500 with old v.11.2.17 IOS configuration:
modemcap entry zyxel:FD=&f*m1s0=1s7=120s10=250:SPD=s20=3:DTE=19200
interface Group-Async1
ip unnumbered Ethernet0
ip access-group 105 out
encapsulation ppp
async default routing
async mode interactive
ntp disable
peer default ip address pool ppp_DialIn
no cdp enable
ppp authentication chap
group-range 1 8
line 1 8
session-timeout 10
no exec-banner
autoselect ppp
login authentication via_tacacs
modem InOut
modem autoconfigure type zyxel
terminal-type download
no editing
transport input all
escape-character NONE
telnet transparent
stopbits 1
rxspeed 19200
txspeed 19200
flowcontrol hardware
didyap
Level 6
Level 6
Removing "autoselect during-login" and adding "autoselect timeout 5". Doing this will allow AAA authentication not to be taken immediately after the connection is made.
