WLC 4400 Cannot send an ARP reply
Jun 5th, 2007
Has anybody seen this error message. "dtlArpRequest: Cannot send an ARP reply to 00:0B:85:86:4D:20" It happens when I change the WLC to lag. It works fine without lag turned on. There is about 17 aps on it. As soon as I turn it on and reboot the WLC about 10 of the aps come up. Over time the aps get fewer and fewer until there is 0 aps. Any ideas?? I have checked the switch config per cisco specs and I still have same problem. I have upgraded to 4.0.206 to 4.1.
ankbhasi Tue, 06/05/2007 - 07:33
  • Cisco Employee,
Hi Friend,
I believe you might have reloaded the controller once after you enabled LAG? Also what is the channel-group mode set to on switch side?
Also can you paste the output of "sh interface sum" from controller?
Ankur
Kevin Conklin Tue, 06/05/2007 - 07:40
I reloaded it multiple times. Channel-group mode is on. I actually can not because lag is turned off now. I can only do it when I take it down. Thanks for the response.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
