Call forward - calling address behavior
Jun 5th, 2007
Does anyone know is there any solution to change calling number of the forwarded calls from the originating number to the called one? My strong interest is to change this behavior for the calls which come from PSTN to CCME and then are forwarded back to PSTN in accordance with IP phones call forward settings. I'm using CCME 4.02 on ISR 3825. PSTN gateway (Pri ISDN) is integrated in the same router.
Thanks in advance.
Andrey
