PVDM2-12DM
Jun 5th, 2007
I have a problem with PVDM2-12DM. I have installed a PVDM2-12DM in a Cisco 2811 with a E1 Controller.
The Output of show diag. is the following.
PVDM Slot 0:
No Card PVDM daughter card
Hardware Revision : 1.0
Part Number : 73-10100-03
Board Revision : B0
Deviation Number : 84758
Fab Version : 03
PCB Serial Number : FOC10223PUR
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-12DM
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 04 8E 41 01 00 82 49 27 74 03 42 42 30
0x10: 88 00 01 4B 16 02 03 C1 8B 46 4F 43 31 30 32 32
0x20: 33 50 55 52 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 8A 50 56 44 4D 32 2D 31 32 44 4D 89 56 30 31 20
0x40: D9 02 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
- What the meaning of "No Card PVDM daughter card"?
- The LED on the router for PVDM0 and PVDM1 is not active . Whay ?.
can somebody help.
paolo bevilacqua Tue, 06/05/2007 - 13:20
  • Hall of Fame,
    Founding Member
the "No Card" part of the output appears to be a cosmetic bug, does the pvdm2 actually work ?
giaaaj Tue, 06/05/2007 - 23:51
No it does not work.
The LED on the Router is inactive and i am not able to configure it in a line command
ACCG007(config)#line ?
<0-326> First Line number
aux Auxiliary line
console Primary terminal line
tty Terminal controller
vty Virtual terminal
x/y Slot/Port for Modems
x/y/z Slot/Subslot/Port for Modems
actualy for a PVDM2-12DM i should be able to configure the line from 322 to 333 ( 12 lines) but i see only the outbut obove.
in an interface Group-Async0
iam not able to configure the group of lines 322-333 see output:
ACCG007(config)#interface Group-Async0
ACCG007(config-if)#grou
ACCG007(config-if)#group-range ?
<1-320> Start of range
Thx
Ali
paolo bevilacqua Wed, 06/06/2007 - 00:20
  • Hall of Fame,
    Founding Member
IOS used? Configuration? Is there an NM-PRI installed ?
giaaaj Fri, 06/15/2007 - 01:45
The problem is solved by upgrading the IOS
