PAT at VPN 3030 concentrator
Jun 5th, 2007
has anyone tested the PAT (NAT for LAN-to-LAN tunnels). In the documentation i can?t find a hint if the Translated network should be one IP or can be a range. The only point i can find is this:
PAT LAN-to-LAN NAT rules are Edenic rules with Port Address Translation.
What is a Edenic rule ?
Thanks for any help/hint !
Christoph
Overall Rating: 5 (1 ratings)
ggilbert Mon, 06/11/2007 - 12:20
Christoph,
I have done this configuration in the lab and it works.
So, here's the scenario - lets say when the remote network is 10.10.10.x/24 - your local network is 20.20.20.x/24 and you want the local network to be translated as 30.30.30.2/32
Then here are the things you would add on the NAT translation section.
Select PAT.
Local Network: 20.20.20.0 WCM: 0.0.0.255
Translated Address: 30.30.30.2 WCM: 0.0.0.0
Remote Network: 10.10.10.0 WCM: 0.0.0.255
On the LAn to LAN section when you configure the Local and remote work, your local network would be 30.30.30.2 WCM: 0.0.0.0 and remote network would be 30.30.30.0 WCM: 0.0.0.255
WCM - Wild Card Mask
Hope this explains what you are trying to do.
Cheers,
Gilbert
c.ohliger Mon, 06/11/2007 - 21:53
Hi Gilbert,
thanks for your answer !
I have some additional questions:
- I assume you tried to use this PAT with several internal clients, my installation failed after the second client is trying to use PAT.
-Have you tried to use several IPs for the PAT, for example Translated Address 30.30.30.128 WCM: 0.0.0.127 ?
- Do you know what edenic from the documentation means ?
- What version are you using on the concentrator ?
Christoph
