Can LMS 2.6 report on these?
Jun 5th, 2007
  • Gold, 750 points or more
"How many total interfaces (physical and logical) are in the network? This would include all router, switch and firewall interfaces along with all vlans, subinterfaces, etc."
Overall Rating: 5 (1 ratings)
jreekers Tue, 06/05/2007 - 15:30
  • Cisco Employee,
hmmmmm....I know you can get the number managed in DFM by issuing the following command:
#/opt/CSCOpx/objects/smarts/bin/sm_tpmgr --server=DFM --sizes
Does that help?
-Joe
Joe Clarke Tue, 06/05/2007 - 21:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Assuming all devices are managed by RME, you can create an Inventory Custom Report with the rule:
Interface:Type:equals:All
The will produce a report that lists all interfaces in the format "device interface type". For example:
nms-6506a VLAN 17 propVirtual
If this report is generated using cwcli (or exported from the GUI), you can count the lines of output to get a total number of interfaces.
Using RME is probably the most reliable way since it generally manages the bulk of devices in the network.
