LMS 2.6: Two problems with RME inventory reporting
Jun 5th, 2007
  • Gold, 750 points or more
I created a custom template that reports in two columns (Device Type - Model) and (Image - Image Version). The first problem is the report is not sortable by Device Name. "Device Name" is clickable, but the names are not sorted. The second problem is, when sorted by Image Version, the Image Version fields are left empty for a bunch 6.x PIXes after exporting to csv format. I'm attaching a screenshot. Now, there's a third problem I don't particularly care for at this time, but with the same sort order (by Image Version), the PDF-format export does retain all the fields, though the output is not sorted by Image Version at all or any order, and the two columns (Model and Image Version) are split as if they're two separate reports. So it's Device Name + Model first, followed by Device Name + Image Version.
Joe Clarke Tue, 06/05/2007 - 21:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The latter problem is related to CSCsh75048. The former two appear to be new bugs, and at least the sorting one has not been fixed in LMS 3.0.
