Correlating device name to assigned number in the archive directory...
Answered Question
Jun 5th, 2007
In RME 3.5- I access the DEV_FQN table in the dbreader to see what device is associated with it?s associated number to find what directory in the archive/config directory to go to see a device?s configs
RME 3.5
Directory structure
[email protected] > pwd
/var/adm/CSCOpx/files/archive/config
[email protected] >ls
10535 11065 11502 11982 12382 12789 13209 13589 14060 3735 4932 5534
[email protected] >
RME 4.x
Directory structure
# pwd
/var/adm/CSCOpx/files/rme/dcma/devfiles
# ls
269 270 273 274 277 278
How can I correlate the numbers in RME 4.x to do the same thing?
Correct Answer by Joe Clarke about 9 years 7 months ago
This action is not supported, and not really required as you can always get to the latest version of the config using the user-friendly shadow directory. However, these IDs are the RME NetworkElementID as found in the DM_Dev_State table in the RME database. The NetworkElementID can be mapped to a DCR ID in that table, then the DCR ID can be mapped to a device name using dcrcli.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 06/05/2007 - 21:21
