CallManager 5.1 CallManager service
Jun 5th, 2007
I have installed the callmanger 5.1; and installed the DLU as well but i cannot activate the callmanager service ...
Overall Rating: 5 (2 ratings)
thisisshanky Tue, 06/05/2007 - 10:12
DLUs are for phones. You need to install one node license per every node for CM service to be up and running. If you have a pub and sub, you need two node licenses.
PS: please remember to rate posts!
incc Tue, 06/05/2007 - 10:19
Thanks for the reply... what is the procedure to buy node license ? It Does not come with the purchase of callmanager server ?
thisisshanky Tue, 06/05/2007 - 10:36
You need to get a node license according to the server you have. If you have a 7835, you ll need LIC-CM5.0-7835-H1= (for a HP server).
