stephan.steiner Thu, 06/07/2007 - 04:44
  • Silver, 250 points or more
No.. and a little more info wouldn't hurt. What exactly are you trying to debug? An application running on the IIS on your box? That will turn out to be problematic as IPC, as every other Cisco phone, runs a webserver on port 80.. so your port 80 will be blocked when the IPC is running.
3tciscosupport Thu, 06/07/2007 - 11:08
Yes, that's exactly what's happening. Is there any way to change the port that the IPC webserver uses?
Thanks.
