3750 stack software compatibility
Jun 5th, 2007
Does anyone know which IPBASE image would be compatible with 12.2(25)SEB1 to stack, or where I could get hold of that particular image please?
Many thanks,
J
Overall Rating: 2.5 (2 ratings)
Anand Narayana Tue, 06/05/2007 - 21:08
  • Silver, 250 points or more
Hi J,
there is nothing like a particular image will only support the stacking feature in Cisco 3750, all the Cisco 3750 switches which comes directly from the factory will support the stacking feature.
jigsaw2026 Wed, 06/06/2007 - 00:12
Thanks Anandanarayana, I understand that they support stacking, but when I stack them it comes up with version mismatch/incompatible software.
jigsaw2026 Wed, 06/06/2007 - 00:14
Hi Spremkumar, thanks for the link I will take a look at it.
J
Anand Narayana Wed, 06/06/2007 - 00:18
Hi J,
i du agree with the message "version mismatch" which u get. that is bcoz, when you connect a additional switch in the existing stack, the existing stack switch will try to upgrade the IOS to the newly added switch automatically, if the existing stack switch finds there is a IOS version different from that, u get this message.
i hope you understood .
