06-05-2007 10:27 AM - edited 07-03-2021 02:10 PM
Hi all, i have a 4402 controller with 17 ap on line, i am using this system to give wireless service to several machine in a manufacturing plant, if i go to the terminal the coverage is very good but the speed on the card go down until only get 1 MB of speed. I am wondering if this is problem of overlapping, saturatio IT's a big problem., please advice.
Thanks in advance.
06-08-2007 09:22 AM
likely you have a lot of noise in your your environment. Review your SNR via 'show dot11 ass all'
this could be caused by co-channel interference (CCI), where two APs are on say channel 1.. Or it may be adjacent channel interference (ACI) which is when you have one ap on channel 1 and the other is say on channel 3. Other sources COULD be machinery, cordless phones, microwaves etc.
You may want to look into borrowing/renting/buying a spectrum analyzer.
06-12-2007 10:25 PM
What are the datarates set to in the controller?
What are the power / channel settings set to?
If you are getting 1 Mbps speeds then you are most likely allowing them. Otherwise, you would be seeing holes in your coverage.
If you only allowed 11Mbps, then any spot where you are getting a 1Mbps datarate would theoretically, not work.
However, you advertise good coverage.
Now all this combined with the above mentioned noisy environment...
What were the parameters / results of the site survey?
