SFP compatibility with 10gbE?
Answered Question
Jun 5th, 2007
Someone knows if a SFP (GLC-SX-MM=) works with a fiber optic patch cord 10gbE? As a port FE works with a UTP Cat.6 cable (obviously at 100Mb).
Correct Answer by balajitvk about 9 years 11 months ago
Most of the 10GBE fiber patch chords are using 50um Core Size and if your patch chord is of 50um or 62.5um then 1000BASE-SX short wavelength GLC-SX-MM will support the same....
Rate if it does,
Rgs
Overall Rating: 5 (1 ratings)
Martin Parry Wed, 06/06/2007 - 07:50
  • Silver, 250 points or more
The GLC-SX-MM is only capable of running at 1000BaseSX over multimode fibre. It will not operate at 10GB
silrodri05 Wed, 06/06/2007 - 09:28
Hi Parry,
I know that it will not work in 10gb, but my question is will function in 1gb with a fiber optic patch cord 10gbE, to only understand if it has some physical problem of the compatibility.
Correct Answer
balajitvk Thu, 06/07/2007 - 08:53
Rate if it does,
Rgs
Amit Singh Thu, 06/07/2007 - 08:58
  • Cisco Employee,
Yeah, I agree with Balaji on this. the same multimode fiaber patch cable and work for both 10GB and 1GB connection. You have to just change the GBIC connector for either 1G connectivity or 10GB connectivity.
HTH,
-amit singh
