2924XL switch showing undersize input packets
Jun 5th, 2007
7206 with IO controller and PA-FE-TX running c7200-is-mz.123-14.T2.bin connected to a 2924XL running c2900XL-c3h2s-mz-120.5-XU.bin. Excessive input errors experienced on 2924XL switch port from router:
TGP-PRODSW#sho int fa 0/24
FastEthernet0/24 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.7d35.cb58 (bia 0002.7d35.cb58)
Description: TGP Production Router Fa 4/0.1
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 245/255, txload 1/255, rxload 5/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:17, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 2054000 bits/sec, 234 packets/sec
5 minute output rate 254000 bits/sec, 216 packets/sec
205622 packets input, 224228456 bytes
Received 4790 broadcasts, 15467 runts, 0 giants, 0 throttles
15467 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 257 multicast
178268 packets output, 29248414 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 lost carrier, 0 no carrier
TGP-PRODSW#sho controllers ethernet-controller fa 0/24
Transmit Receive
30008640 Bytes 233020574 Bytes
178969 Unicast frames 207670 Unicast frames
4274 Multicast frames 258 Multicast frames
367 Broadcast frames 1096 Broadcast frames
0 Discarded frames 0 No bandwidth frames
0 Too old frames 0 No buffers frames
0 Deferred frames 217 No dest, unicast
0 1 collision frames 2 No dest, multicast
0 2 collision frames 3449 No dest, broadcast
0 3 collision frames 0 Alignment errors
0 4 collision frames 0 FCS errors
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 15814 Undersize frames
0 8 collision frames 6300 Minimum size frames
0 9 collision frames 29186 65 to 127 byte frames
0 10 collision frames 6696 128 to 255 byte frames
0 11 collision frames 9727 256 to 511 byte frames
0 12 collision frames 19470 512 to 1023 byte frames
0 13 collision frames 141313 1024 to 1518 byte frames
0 14 collision frames 0 Oversize frames
0 15 collision frames
0 Excessive collisions
0 Late collisions
Speed/duplex on both ends hard-set to 100-full across a 4-5 foot CAT5 patch cable between the two systems. Spare PA-FE-TX card, spare 2924XL, and another patch cables all tried with same results. No other port on switch showing these issues.
Thoughts - IOS bug in router???
glen.grant Tue, 06/05/2007 - 12:36
  • Purple, 4500 points or more
Can't you post both interface configs , still looks like a speed/duplex issue as you are getting runts and input errors and also your reliability field only shows 245/255 , it should show 255/255 . Post a "show int status" from the 2924.
mduke Tue, 06/05/2007 - 12:45
'show int status' command not supported in this version of IOS.
Switch:
interface FastEthernet0/24
description TGP Production Router Fa 4/0.1
duplex full
speed 100
switchport mode trunk
Router:
interface FastEthernet4/0
description PROD_TRUNK
no ip address
no ip redirects
no ip unreachables
ip route-cache flow
no ip mroute-cache
duplex full
interface FastEthernet4/0.1
description Connected to WLT&FOR-MANAGE_NET
encapsulation dot1Q 1 native
ip address x/y secondary
ip address x/y
no snmp trap link-status
interface FastEthernet4/0.2
description Connected to WLT_BRDNT_&_YCI
encapsulation dot1Q 2
ip address x/y
ip access-group CUSTOMER_BLINDERS_WITH_PROTECT in
no ip redirects
no ip unreachables
no cdp enable
interface FastEthernet4/0.3
description Connected to WLT_CANOPY_&_FOR_BRDNT
encapsulation dot1Q 3
ip address x/y ip access-group CUSTOMER_BLINDERS_WITHPROTECT in
no ip redirects
no ip unreachables
no cdp enable
interface FastEthernet4/0.4
description Connected to FOR Canopy
encapsulation dot1Q 4
ip address x/y
no ip redirects
no ip unreachables
no cdp enable
glen.grant Tue, 06/05/2007 - 13:57
You are right don't see anything specific there , check to see if the router interface will take a speed command . Some FE interfaces were configurable for 10 or 100 , it might help to hardcode the speed if it takes it . If there is no speed command then not sure what it would be but it sure doesn't look right with the runts and the reliability field way off . Did you try a different port on the 2924 and did the problem still show itself? Also on the FE interfaces if it has both a fiber and copper port for the same interface you have to select the media type . Don't know off the top of my head whether you have to do that with your FE adaptor or not , just something to keep in mind.
mduke Tue, 06/05/2007 - 14:05
Router doesn't support the speed command. Switch was originally connected to the integrated Fast Ethernet port on the I/O controller. Added a PA-FE-TX to the chassis with no change. Tried different switch ports in the original switch with no change. Tried a different switch with no change. Tried different patch cables with no change.
Have swapped everything except the router chassis, I/O controller, and router IOS at this juncture.
