deepagup Sat, 06/09/2007 - 11:33
  • Cisco Employee,
Well the simplest way to find out is .. right click an existing call handler prompt file in unity and check the file properties.
mdury Sat, 06/09/2007 - 14:07
Deepaqup,
Average Data Rate 8.0 kb/second
Sample Rate 8.0 Khz
Audi Sample Size 8.0 Bit
Channels 1 (Mono)
So this is the Optimal quality for a G711ulaw Prompt?
deepagup Sun, 06/17/2007 - 02:10
  • Cisco Employee,
You are right.
If the sample rate is 8.0 Khz and also if sample size is 8 bit then the Data Rate will autimatically be 64Kbps
Every thing else is fine :)
