PoE Question
Answered Question
Jun 5th, 2007
Hello again,
I'm still too nervous to plug my 3rd party PoE device into my phone, heh. I found the exact specifications online and wanted to run it by you pro's before manning up and trying it.
Specs:
RoHS: No
DC Output Connector: RJ45 Connector
Number of Outputs: 1
Product Category: Power Over Ethernet Adapter
Mounting Style: Wall
Output Current (Channel 1): 0.35 A
Output Power Rating: 15.4 W
Output Voltage (Channel 1): 48 V
IEEE 802.3af Approved
Correct Answer by Rob Huffman about 9 years 8 months ago
Hi Don (er Nash)
The 15.4W Output Power Rating is exactly what a Class 3 device like the 7970 is looking for. You really should be good to go here :) This will not cook the phone!
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
mchandak Tue, 06/05/2007 - 12:55
AFAIK, a PoE device can only be connected directly to the switch and not the phone. I've never seen this being used or come across this before. I believe phone cannot handle PoE information recieved on the PC Port of the phone
donjohnson911 Tue, 06/05/2007 - 13:04
Yea sorry I must have not been clear. I meant I have a 3rd party injector that's receiving the signal from a non-PoE router and adding power so I don't need a PWR-CUBE to power the device. Will be put in same input that switch/router comes from not PC port.
Just trying to make absolutely sure those specifications are what I need so I don't burn out the phone.
Correct Answer
Rob Huffman Tue, 06/05/2007 - 13:05
Hi Don (er Nash)
Hope this helps!
Rob
donjohnson911 Tue, 06/05/2007 - 13:12
Thanks so much for the great assistance today, Rob. I know I've asked the same question like 3-4 different times now, and you've been quite patient and helpful. I really appreciate it.
Just want to be absolutely, 150%, positive that it's good. Now I'm confident that I have my answer. :)
Rob Huffman Tue, 06/05/2007 - 13:16
Hey Don.... no worries! Let us know how you make out with this.
Take care,
Rob
