booting rsp4 7500 with boot image on flash disk
etheric
I have seen messages on forum regarding booting the boot image from flash disk.
I did get the 123-14.T7 boot image to load ONCE. I believe i actually had errors in my syntax when it worked:
Here is the show run:
boot system flash disk0:rsp-ik9sv-mz.123-14.T7.bin
boot bootldr disk0:rsp-boot-mz.123-14.T7.bin
boot config disk0:startup-config
logging buffered 300000 informational
no logging rate-limit
logging console informational
Here is the bootvar
c7505-3(boot)#show bootvar
BOOT variable = disk0:rsp-ik9sv-mz.123-14.T7.bin,1;
CONFIG_FILE variable = disk0:startup-config
BOOTLDR variable = disk0:rsp-boot-mz.123-14.T7.bin
INHIBIT_BSI variable does not exist
The device keeps booting to the image in bootflash. 12.2(40)
This is what I want to boot from.
Directory of disk0:/
1 -rw- 26741584 Jun 4 2007 01:18:08 -07:00 rsp-ik9sv-mz.123-14.T7.bin
2 -rw- 10775480 Jun 3 2007 23:33:18 -07:00 rsp-boot-mz.123-14.T7.bin
3 -rw- 1635 Jun 5 2007 14:32:56 -07:00 startup-config
4 -rw- 1635 Jun 5 2007 14:32:42 -07:00 startup-config1
5 -rw- 1635 Jun 5 2007 14:37:06 -07:00 startup-config2
64221184 bytes total (26689536 bytes free)
Q. How do I debug this ?
Q. Why is it not booting correctly?
etheric
I discovered that the older flash drives work.
By inserting a slot0 device the problem seems to be resolved.
I wonder why no error message is generated when the config file "errors out".
This config is working:
boot-start-marker
boot bootldr slot1:rsp-boot-mz.123-14.T7.bin
boot config disk0:startup-config2
boot-end-marker
