Stumped...5505 NAT issue
Jun 5th, 2007
I'm going to go bald early if I don't ask for a hint with this one.
Here is my config:
sho run
: Saved
ASA Version 7.2(2)22
hostname 5505
enable password xxx
interface Vlan1
nameif inside
security-level 100
ip address
interface Vlan2
nameif outside
security-level 0
ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
access-list traffic extended permit ip any any
access-list traffic extended permit icmp any any
access-list nonat extended permit ip any
access-list 100 extended permit ip any
pager lines 24
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list nonat
nat (inside) 10 tcp 5000 500 udp 5000
access-group traffic in interface inside
route outside 1
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address 100
crypto map outside_map 1 set peer
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 1 set reverse-route
crypto map outside_map interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns
dhcpd address inside
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
: end
The other end is a 5510.
Goal - ping accross the VPN tunnel between hosts at each end.
Problem - pings are only succesful after removing the following command: nat (inside) 10 tcp 5000 500 udp 5000
The problem with that is after the command is removed I can no longer browse the web from the inside.
I believe the problem lies with the incomming packets...the ASDM shows a NAT error. The strange part is that the 5510 has the same NAT rules are works fine....heck, I have an ASA 5510 in the field with the same rules that is working fine.
I don't get it.
Thanks in advance.
