How do I inspect when I use site-tosite VPN?
Jun 5th, 2007
  • Gold, 750 points or more
I was implementing site-to-site VPN on the ISR router(SecurityIOS) and the ASA 5510 firewall.
what are protocol that I need to inspect on ISR router?
please advices or point me to useful links.
Thanks in advance
Overall Rating: 4 (2 ratings)
Jon Marshall Wed, 06/06/2007 - 00:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Not entirely sure what you mean. If you mean which protocols do you need to allow for IPSEC to work
UDP port 500
ESP port 50
AH port 51 ( optional as authentication is usually done with ESP).
Jon
thotsaphon Wed, 06/06/2007 - 01:39
Many thanks Jon
Let me explain further.
I implement site-to-site VPN that working just fine.When I configure ip inspect command on router for doing a firewall on ISR router then I can't use site-to-site VPN anymore.
List of commands that I added on ISR router.
: ip inspect name myfirewall https
: ip inspect name myfirewall isakmp
: ip inspect name myfirewall ipsec-msft
Still can't work. what is command that I need to add?
Jon Marshall Wed, 06/06/2007 - 01:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
When you are using inspect what does your access-list that you use allow. You will need to allow the ports and protocols in that access-list before you add a deny any any.
Does this make sense ?.
If not could you post your router config minus any sensitive information.
Jon
srue Wed, 06/06/2007 - 05:45
  • Blue, 1500 points or more
sidenote:
i dont think ASA's support AH, but that seems irrelevant to this thread.
thotsaphon Sun, 06/10/2007 - 00:32
Hi john
Many thanks for your help. Now I achieve this goal. look like this
For ip inspect :
ip inspect name GotoInternet http
ip inspect name GotoInternet https
To deny all traffics from untrust zone and allow necessary port for site-to-site VPN
ip access-list extended DenyAnyTraffic
permit udp host x.x.x.x any eq isakmp
permit udp host x.x.x.x any eq non500-isakmp
permit udp host x.x.x.x eq isakmp any
permit esp host x.x.x.x any
deny ip any any
I have already created crypto map then apply parameters to interface
interface Serial0/1/1
bandwidth 512
ip address y.y.y.y 255.255.255.252
ip access-group DenyAnyTraffic in
ip nat outside
ip inspect GotoInternet out
ip virtual-reassembly
crypto map XXX
Jon, you would deserve a rating ;-)
L.Thot
