CBWFQ and LLQ
Answered Question
Jun 5th, 2007
Hi, I understand that LLQ is an extension of CBWFQ and is a strict priority class but I am unable to find information as to how to assign traffic flows/types to the LLQ queue. Is this done by a command of some sort e.g setting a DSCP value? Or does the router automatically assign traffic flows to the priority class itself? I think it may have something to do with the EF DSCP value, but I am not certain.
Thank you in advance.
Correct Answer by royalblues about 9 years 11 months ago
Yes you are correct.
LLQ is an option applied to CBWFQ under one or more classes. CBWFQ treats these classes as strict priority queues and always services packets in these classes.
HTH, rate if it does
Narayan
Overall Rating: 4 (2 ratings)
royalblues Tue, 06/05/2007 - 20:47
  • Green, 3000 points or more
Friend,
The traffic flows are assigned to the LLQ using the "priority" command under the policy map.
When you do QoS for giving priority to a certain traffic, you need to classify that traffic. DSCP is just one way of doing it. Additionally you can also set/mark the DSCP values
eg..
class-map match-all voice
match ip dscp ef
policy-map LLQ
class voice
priority 512
class class-default
fair-queue
Narayan
voiper_99 Tue, 06/05/2007 - 20:53
Ahh I see what you mean. So what you are saying is that the bandwidth assigned to the policy map (with the priority command) gives that policy map a slice of the "strict LLQ priority queue". Is that correct?
By the way thank you for the quick reply.
Correct Answer
royalblues Tue, 06/05/2007 - 21:04
Narayan
