06-05-2007 09:02 PM - edited 03-11-2019 03:25 AM
i am having 1 5520 with csc-ssm module. can p2p aaplications, url filtering be restriected by this? if so please help me with config.
06-05-2007 09:43 PM
p2p applications can be blocked using the IPS module AIP-SSM.
URL Filtering can be done using CSC-SSM module if you do have a Security Plus license.
For detail configuration since its GUI based you can paste the configuration.
Have a look at this page
http://www.cisco.com/en/US/docs/security/csc/csc61/administration/guide/csc4.html#wp1040852
-Hoogen
Do rate if this helps :)
06-06-2007 02:31 AM
thanks hoogen..but i have csm-ssm. can p2p applications be blocked by using pbr on firewall?
if so then do u have any sample config..
