QM_ideal and MM_active same ??????
Jun 5th, 2007
I eastablish VPN in pix 7.0.
but i input show crypto isakmp sa
then founf MM_active but not QM_ideal .
in router:
Router# show crypto isakmp sa
f_vrf/i_vrf dst src state conn-id slot
/vpn2 172.21.114.123 10.1.1.1 QM_IDLE 13 0
but in pix shows
state MM_Active
so it is same ?
Biplob
Jon Marshall Tue, 06/05/2007 - 23:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Biplob
QM_IDLE indicates that Phase 1 of the IPSEC negotiation has been sucessful.
MM_Active (MM = Main Mode) means that Phase 1 of IPSEC negotiation is still happening and has not been successful as yet.
Jon
