CSA detects rootkit, but no process is shown in event
Jun 6th, 2007
I am getting a strange event during a csa 5.2 pilot, csa detects a rootkit but it does not in the details tell me what process it is, but only this memory address as Pstring : [email protected]
Anybody know what this is, and how i could find out what process is doing this ? pslist doesn't show any unknown processes that would indicate some sort of malware.
228822549 Tue, 06/12/2007 - 11:05
Requesting guidance... I'm having a very hard time finding CSA professionals who can manage multiple implementation on CSA. I thought the best thing to do was to go to the source and ask for suggestions as to how I can find these "hard to find" gems.
Your assistance is greatly appreciated.
EA
tsteger1 Tue, 06/12/2007 - 13:27
Hi Eileen
Are you looking for implementation guidance or someone to manage the implementations?
Tom
tsteger1 Tue, 06/12/2007 - 13:53
Eileen, can you put a contact email address in your profile?
Tom
228822549 Wed, 06/13/2007 - 06:20
Tom,
I checked the box off in my profile so that you can view my e-mail address. I also sent you an e-mail message.
Looking forward to receiving a message from you.
Eileen
tsteger1 Tue, 06/12/2007 - 13:43
Hi Jan
Is this only happening on one hardware platform?
Rootkit positives are usually hardware drivers like keyboard filters or monitors and touchpad drivers.
Uphclean also reports as a rootkit.
You might be able to make an exception using the memory address string if it rarely changes.
You could also try running Process Explorer from Sysinternals http://www.microsoft.com/technet/sysinternals/utilities/ProcessExplorer.mspx and logging the processes for a while then examining the logs.
The tricky part is that it may only show up at logon or logoff.
Tom
jan.nielsen Tue, 06/12/2007 - 23:07
Hi Tom
Thanks for the reply, i am well aware of the problems with detecting rootkits properly. I am just worried that this is an actual rootkit and not a false positive. I have run pslist and rootkit revealer from sysinternals with no luck, but maybe i should try to monitor a little closer during boot, and my next step is to go to the site where the pc is located and check it myself.
