smothuku Wed, 06/06/2007 - 02:25
Hi ,
Can you paste the show version output.
satish
glen.grant Wed, 06/06/2007 - 03:19
you probably have one of the old 4 meg models which does not support tacacs . Do a show version and see how ram it has , if it says 4096 then it does not support it , if it says 8 meg then it should if your code level is high enough.
fargier Wed, 06/06/2007 - 03:45
Can you use radius-server host
and after use aaa authenticat... tacacs
If i remember well it seems to works with tacacs +
