UCCE 7.0 - IBM MQ (aka MQ Series)
Jun 6th, 2007
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
our customer demands us to send/receive information from UCCE 7.0 to MQ (or MQSeries).
Does anyone have any idea how we could achieve this?
Thanks very much in advance.
szge
lpezj Wed, 06/06/2007 - 03:07
  • Gold, 750 points or more
You could try two options, but I think that they are complex:
- Use and Application Gateway to communicate with MQ Series.
- Use java with Cisco IP/IVR to communicate with MQ Series (if it were possible).
I think that it is easy to say, but quite difficult to do it.
Hope this helps,
Juan Luis
Gergely Szabo Wed, 06/06/2007 - 03:12
Well, yes, actually, MQ does not work like an SQL lookup, we should create new Java classes and stuff if we decide to go the IVR way.
Application Gateway is not an option here, I guess, would be too complicated to build up a completely new system...
G.
