Calling-Station-Id
derekgaff
Maybe you can help me here. I'm currently testing ezvpn connectivty into our MPLS network for our clients remote access LAN-to-LAN VPN. This is working fine, but I have an issue with two things.
First, can I assign an IP Address to a client based on there calling-station ID, this is basically because the clinet is assigened an IP Address based on the Group username/password and not there username.
Second, is there another way to get the RADIUS server to assign the IP Address based on the username insted of the goup username. As all clients belonging to the same VRF have the same Group username/password.
Thanks in advanced.
Derek
Premdeep Banga
Level 7
Level 7
If you have ACS 4.x, then you can play with NAP(so that we can filter/identify request on the bases of Calling-Station-Id or username) and for IP address assignment, in NAP use RAC.
Give it a try.
Prem
